Bubbles in fuel filter
Old Oct 8, 2007 | 12:16 PM
Kaukasion's Avatar
Car: 84 z28
Engine: older 350, details unknown
Transmission: th350
Axle/Gears: factory limited slip
Re: Third fuel line
hey guys not to steal the topic but i disconnected the canister vac line from my edelbrock
and i have noticed when i shut the motor off small air bubbles coming up through my fuel filter ("see through one") and am wondering if that is going to hurt anything, also if you use a vented cap should you remove the trap flap from the fuel cap area? just wondering if that would help the pressure get out of the tank
Old Oct 8, 2007 | 02:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
This is a different topic, so I have moved it to it's own thread.
(TGO policy is to keep threads to the originator's topic.)
The bubbles are vaporizing fuel. Not exactly a desirable condition, can lead to hard starting after sitting hot.
The "trap flap", as you call it, is carryover from the days of leaded fuel. When unleaded fuels were required starting in 1975 in cars with catalytic converters, they put a "restrictor" in the fuel fill to keep a leaded gas nozzle from fitting in the tank, and that little flap to keep people from trying to just pour it into the filler. It has no effect whatsoever on tank venting.
Old Oct 8, 2007 | 04:43 PM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
Re: Bubbles in fuel filter
thanks five 7
im learning alot reading around here
gave up on the pos trans am and just bought this crappy z for 500 and trying to get it running right
oops forgot
so what type of vented cap should i get
do you have any recommendations
Old Oct 8, 2007 | 06:02 PM
five7kid's Avatar
My recommendation would be to keep the stock vapor canister and unvented fuel cap.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
