what size carb for this setup
Old Oct 19, 2007 | 12:34 AM
transam360's Avatar
Car: 1986 caged out firebird
Engine: 454 = wheelies
Transmission: th400 stall and trans brake
Axle/Gears: 4:11 ford 9" with ladder bars
ok i am building a 454 i would just like the estimated the size of carb I need for my engine here are the specs the engine is bored .060 over and the pistons are kb 25.5 dome pistons with a compression ratio of 11.1 to 1 the heads are a ported ovel port head ad the cam is a .560 / .573 lift and 240 int./246 exh. at .050 and a 112 Lobe Separation plus i have 1.8 roller rockers the intake is a weind intake good from 1500 rpm to 6500 rpm so it matches the cam also have hooker long tube headers
Old Oct 19, 2007 | 01:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
No less than an 850.
What is the planned use?
Old Oct 19, 2007 | 02:33 PM
transam360's Avatar
Re: what size carb for this setup
mostly track but some street use like once a week
Old Oct 19, 2007 | 06:18 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
A 850 cfm at minimum. A 950cfm carb is not too big.
Comp cams CB-280S-10 #12-551-5 a better cam. it a mechanical grind.
Old Oct 19, 2007 | 06:57 PM
transam360's Avatar
well i already have all the parts including the cam so i am going to stick with the one i got.
toronto formula
Nov 10, 2015 06:17 AM
gta90
Sep 15, 2015 04:00 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
