Q-Jet and my EGR Help!!!
Old Nov 16, 2007 | 06:23 PM
CBerlinetta85's Avatar
I have a 1985 Chevy Camaro Berlinetta with the LG4 engine and i just out in an edelbrock 2101 intake without Egr and know the car just stalls when i start it up. i was told its because the carb is computer controled and with out the EGR its confused and screwing up the mix. is there any way i can disconect something and trick the carb, or anything? thanks
Old Nov 16, 2007 | 06:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
There's nothing to that. The computer expects to see a load on the EGR solenoid or it'll set a trouble code, but that's it. I've got my solenoid hooked up but no EGR valve (vacuum source plugged off), and it runs just fine.
Look for vacuum leaks or something not adjusted properly - timing (did you set it with a timing light and the EST connector disconnected?), other carb adjustments (IAB, TPS, etc.).
Old Nov 17, 2007 | 12:59 PM
Re: Q-Jet and my EGR Help!!!
I wanna try and get one problem at a time away so should i keep the selinoid conected and plug the the carb hole? also i just tryed something new i taped the choke plate colsed and i got it to idle but at a really high rpm and tryed spraying carb spray around never got a change in idle?????
Old Nov 17, 2007 | 01:53 PM
five7kid's Avatar
One thing at a time is a good approach. Timing is #1. Vacuum leaks, carb adjustments next.
Old Nov 18, 2007 | 12:47 PM
Thanks i'll try to figure it out im pretty sure it might the timing hopefully ill post when i get it fixed
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
