Fuel Volume?
Old Nov 15, 2007 | 04:06 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Fuel Volume?
Tried doing a quick search and couldn't find what I was looking for. Maybe someone can refresh my memory on what the volume parameters are for a carbed engine? For some reason 1 pt in 15 sec (free flow) is sticking in my memeory but was wanting some verification.
Old Nov 15, 2007 | 04:46 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Fuel Volume?
depends on how much power you are making. Typically you measure how long it takes to fill a 1 gallon container, then you can get a gph reading which would tell a HP conversion, I believe magnafuel has them on their website. Regardless a fuel pressure guage is good to have on a drag car to watch it in 3rd gear is when demand would be highest.
Old Nov 18, 2007 | 01:51 PM
fulo's Avatar
Car: Z-28
Engine: 355
Axle/Gears: Stock
Re: Fuel Volume?
from the Chilton Book:
Volume test:
Assuming, the pressure is good (about 5 PSI) the lines are not obstructed and filter is clean.
Run the fuel line to a graduated container. Run engine at idle. It should take approx. 30 seconds or less to fill one one pint. If less, there migth be a problem with pump
Old Nov 18, 2007 | 02:13 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Fuel Volume?
Good info and formulas for finding how much of a fuel pump (based on its free flow rating) and what size fuel lines you need to support a engine of a known horsepower output.
http://www.centuryperformance.com/fuel.asp
Thornburg
Aug 25, 2015 01:46 AM
92camaroJoe
Aug 13, 2015 06:07 AM
BBSDesigns
Aug 11, 2015 07:39 PM
