carb problem on engine swap!help please guys!!
Car: 1982 FIREBIRD-1983 CAMARO
Engine: 305 LG4
Transmission: TH350-TH200
my friend is restoring a 1983 camaro berlinetta.he remove the v6 engine and he put a 260ci v8 oldsmobile engine out of a cutlass.this motor is factory equiped with a 2bbl rochester carb.my friend install a holley street domintor intake and a 4bbl holley carb with mechanical secondary.now when the car is cold works just fine but when the car rich normal temprature the engine stops...sometimes backfires...wont start easy again...and when it does when you put the trans in drive or reverse and touch the gas pedal the engine stops again.i think that the carb is too big for that engine and overflows with too rich mixture but i want to hear your opinion.thanks a loy guys!
Transmission: 4L80E/4L80E
How big is the carburetor? About 450 CFM is all it could ever need.
Engine: 305 LG4
Re: carb problem on engine swap!help please guys!!
i think it is a 600-650 cfm!i checked and the smaller 4bbl that the holley gives is the 600fcm.do you know if there is a 450-500cfm 4bbl carb.?
Engine: 305 LG4
thanks a lot my friend!i found it...it says that has a square bore patern...i hope it fits holley street dominator intake!
The Holley Street Dominator mounts square bore carbs.
Looking at that carb again, it's for multiple carb systems only. It doesn't have a secondary pump, even though the secondaries are mechanical, so that isn't a good idea.
Perhaps the 0-8007 instead. 390 CFM, vacuum secondary.
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
