Power Valve Recomendation
Car: 89RS
Engine: Lo3 bored.030 over, 230/480comp cam
Transmission: 700r4 10" converter
Axle/Gears: Stock G80 2.73
I recently installed a comp cam 280h in my 305 and I have a Holley 4160 600 cfm carb with the stock power valve,which is a 65. At idle in park I have 11 inches vacuum, and in gear I have 7-8 inches. I notice when I quickly step on the gas it hesitates for a moment but then it starts to boogie. From reading around the threads it seems that i may need a different PV size, just wondering if anyone had any ideas?
Thanks,
Kronos
Thanks,
Kronos
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Power Valve Recomendation
you should have more vacuum at idle than that with that cam, did you adjust your idle mixture screws for maximum vacuum while idling hot in gear? Are you trying to floor it from a stop? if so then i'd say you need to adjust your secondary spring tension with a stiffer secondary spring, it might be opening too soon causing the bog you describe.
Car: 89RS
I actually have yet to adjust the idle mixture screws, and the hesitation happens anytime when I floor it. The secondary spring that is in there is what came with the carb and it takes a while for it to open, so it's kinda tight. Even when I'm cruising I get little bumps in the idle, almost sounds like a miss. When I go to WOT there is the little hesitation, and then it smooths out while on the throttle.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
recurve the distributor to allow more timing at idle. 20-24deg
A 4.5" power valve is best
ambainb
Apr 25, 2016 09:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
