fuel problem
Old Dec 23, 2007 | 09:53 PM
btjz28's Avatar
fuel problem
i just recently bought a 85 chevy truck. after about 30 minutes of driving it feels like the gas cuts out. I replaced the electric fuel pump the in line filter and took out the filter in the carb. Is there a pump in side the tanks. if not what else could it be. any suggestions? thanks
Old Dec 23, 2007 | 11:21 PM
lonman89's Avatar
Car: 1985 chevy camaro IROC-Z
Engine: 5.7 litre 350 4 bolt main
Transmission: 700r w/B&M shift kit
Axle/Gears: 10 bolt w/3:42 gears
Re: fuel problem
well if its carb'd then it should have a mechanical fuel pump on the side of the block,a electric fuel pump would pump like 20-30 psi and that would literally drown a carb,you need like 5-8 psi to run a carb properly,thats all i can say,there will be better people on here to help you out as im still learnin about old motors and such
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
