hooking up elec. choke
Old Jan 18, 2008 | 04:39 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
where did you guys get the 12v power for the choke?i have an edelbrock 1406 carb
Old Jan 18, 2008 | 09:21 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Find or run an ignition-switched 12v source. It's usually best to avoid tapping directly into the wire that powers the ignition itself to avoid draining off voltage from it.
Old Jan 18, 2008 | 01:03 PM
Re: hooking up elec. choke
i know that, i should have worded the question differently. what exactaly did you guys use? radio, is there anything under the hood i could tap into?
Old Jan 19, 2008 | 12:39 PM
camaro91's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: strange s60 4th gen width - 3.73
for an ignition signal for my remote lock module, i used the fan fuse... it should provide a signal that only comes through when the car turns on... i'm not quite sure if its a 12v tho
Z28/ZR1
Oct 23, 2015 01:04 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
