What are edelbrock carbs built from?
Old Jan 18, 2008 | 10:34 PM
Nsomnia's Avatar
The 1406 I bought used has some rough life to it, no where near shiny.
Are they made from aluminium, thus have oxidized over time to cause a blotchy look and thus can be polished or do I need to have it chromed or something?
Old Jan 18, 2008 | 11:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What are edelbrock carbs built from?
They're aluminum.
Old Jan 19, 2008 | 03:04 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Soak the whole thing in a bucket of gas. Then take an old toothbrush and clean it up. It WILL get like that again. If you already have it on the car jst sprayit down all overs with carb cleaner and then toothbrush it.
Old Jan 19, 2008 | 03:09 PM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
Carb cleaner leaves a dull grey/white residue though, you can polish it out but it will be hard to get the nooks and crannies of the carb.. i would just use an all purpose grease cutting cleaner like chomp.
BTW carbs are VERY easy to remove so take it off and clean it
Last edited by creepingdeath; Jan 19, 2008 at 03:11 PM. Reason: Automerged Doublepost
Old Jan 19, 2008 | 08:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Take it off, disassemble it, and dip the metal parts in real carb cleaner (the stuff in a steel bucket, with a dipping basket) for about 6-8 hours and it'll be all clean again. Not shiny like new, but all the oxidation will be gone.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
