adapting spread to square bore
Old Jan 20, 2008 | 01:03 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
I've read elsewhere that using an adapter plate to use a square bore carb on a stock spread bore manifold costs power. I've searched this site and found only a couple of passing references. So, better of to match them up properly, right?
Old Jan 20, 2008 | 01:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: adapting spread to square bore
Yes, its better to match carb to intake. Many intakes have dual-pattern setups, that can work with a spreadbore and squarebore carb, like the Edelbrock RPM-Qjet intake, and they are fine. The spacers can cause some weird running issues though. I'd avoid using the adapters if possible.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
hartsmike
Oct 2, 2015 07:11 AM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
