Mighty demon 650 acting up
Old Feb 4, 2008 | 10:32 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
During the summer my car started acting up. When i first put the new carb on it only took 2-3 pumps to get the car started. At the end of the summer it wouldnt start with 2-3pumps I had to hit the gas pedal to WOT until the car started ( only took about 10-15 seconds). Would it be time for a rebuild on the mighty demon ??
Old Feb 4, 2008 | 11:40 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Mighty demon 650 acting up
are your plugs fouled out? Are the float bowls draining back over night and you're trying to start the engine without the carb filled? How's the timing? My carb car starts up within 3 seconds of cranking usually, so something isn't right on your setup.
Old Feb 4, 2008 | 11:47 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Plugs are fouled its been running rich since i got it and it has the stock jetting in it. timing is set at 36 degrees. And i dont think the bowls are draining.
Old Feb 4, 2008 | 01:46 PM
EvilCartman's Avatar
Car: '82 Z28
I think it's about time you tuned the carb and put a fresh set of plugs in.
Old Feb 4, 2008 | 02:01 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Think it just might be bad plugs ?
Old Feb 4, 2008 | 03:39 PM
xpndbl3's Avatar
Car: 1984 Z28
no bad tune which fouls out the plugs. you need fresh plugs and to tune the carb.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
bbsr72
Apr 2, 2016 09:12 AM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
