tpi to carb... input please
Old Feb 7, 2008 | 05:26 PM
tpicamarokid85's Avatar
Car: 1985 Z28 (project) drive 2006 F-150
Engine: to be deturmined
Transmission: to be powerglide
Axle/Gears: to be 9".. spool.. possibly 5.14:1
looking to swap the tpi to carb..... future build is L98... looking to stroke it to 383 with eagle rotating assy. and speedpro pistons and rings (.030 overbore)... edelbrock performer RPM cam, RPM heads, RPM airgap intake man. and thunder avs 650cfm carb. i want to port/polish/gasket match the heads and intake man. to open them up a little closer to 190cc because i dont think the 170cc ports will flow enough air. any comments, suggestions will be greatly appreciated. one question is will 650cfm flow enough fuel for the 383 or do i need to step up to 800cfm? looking at about 10.5 to 11:1 compression ratio... natural asperated... t-56 swap and 12 bolt rearend swap. maybe 450hp to flywheel
Old Feb 7, 2008 | 05:48 PM
Re: tpi to carb... input please
no comments??? c'mon guys let me hear it
Old Feb 7, 2008 | 06:32 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
tpi to carb swap has been covered here many times over. I would look in to different companies for the heads cam and carb. Edelbrock makes great intakes but there carbs leave much to be desired. If I where you I would look in to a proform or a quick fuel 750 cfm.
Old Feb 11, 2008 | 11:55 AM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
why would you buy 170cc heads then try to port em to 190cc if i was you i would just buy a set of afr 195cc and not worry about any porting
italiano67
Dec 11, 2016 09:21 AM
dcbsracing007
Aug 28, 2015 04:53 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
