Fuel Pump?
Old Feb 8, 2008 | 05:16 PM
jaredc91's Avatar
Fuel Pump?
i didn't know where to put this so here it is. If the moderators want to move it thats fine. Yesterday I replaced my valve cover gaskets and the passenger side was a major pain but I got it done. then when I went to start the car it just kept cranking. I have a clear fuel filter and there was nothing in it. i assumed that it was the fuel pump and replaced it and I still have the same problem. also, there is fuel coming into the pump beause when I remove the hose coming from the tank the gas keeps siphoning out. Any help would be appreciated.
And BTW I have an 83 z28 with an LG4
Old Feb 8, 2008 | 05:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fuel Pump?
Was it working before you replaced the valvecover gaskets?
Old Feb 8, 2008 | 05:35 PM
jaredc91's Avatar
Re: Fuel Pump?
yes It was working before I replaced the valve cover gaskets
Old Feb 8, 2008 | 05:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Fuel Pump?
Did you have the fuel line disconnected? How long did you crank it before you gave up?
Old Feb 8, 2008 | 05:41 PM
jaredc91's Avatar
Re: Fuel Pump?
I disconnected all the fuel lines to replace the fuel pump and I cranked it for about 5 minutes intermittently and about 1 solid minute. it starts if I pour gas into the carb
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
