smoke out of carb
Old Feb 9, 2008 | 05:46 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
smoke out of carb
i just switched to a holley blue pump when i turn the motor off there is white smoke coming out of the carb it used to do it before but not as much. is it just unburnt fuel.
Old Feb 9, 2008 | 06:25 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: smoke out of carb
I think it's all in your head, unless the pump is putting out too high a fuel pressure?
Old Feb 10, 2008 | 02:55 AM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
Might want to check and adjust float levels. Check the pressure too. Yes, it is most likely unburnt fuel.
Old Feb 10, 2008 | 05:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
When you shut the engine off, fuel gets drawn into the intake manifold that never makes it into the combustion chamber. The heat in the intake manifold and engine vaporizes that fuel, and some of it makes its way up out of the carb. When it hits the cooler air, it "fogs" into visible small droplets which looks like smoke. It's more like a cloud than smoke.
Completely normal. The factory put a charcoal bed into the air cleaner to absorb those vapors and keep them from getting into the atmosphere.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
69GTOby
Apr 18, 2016 02:34 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
Accerrito22
Sep 5, 2015 09:34 PM
