TPI to Carb wiring help VATS and Fuel Pump
Car: 1992 Trans Am
Engine: 355
Transmission: M21
Axle/Gears: 3.70 9 bolt
I just made my 1992 TA from TPI to carb. I am running the intank pump with regulator. How can I wire the fuel purm to a toggle switch, or keyed hot? Also, how do I take out VATS? I dont want to use the resistor, because it is Sunday night, and no stores are open to get the resistor. I need this car for tomorrow morning. Thanks
Rick
Rick
Car: 1992 Trans Am
Engine: 355
Transmission: M21
Re: TPI to Carb wiring help VATS and Fuel Pump
I did the fuel pump bu pulling up the rear carpet and taking the grey wire and running it to a switch to the fuse box. Now all i need is the VATS.
Rick
Rick
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
ground out the starter enabler relay in the drivers kick panel IIRC
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
