Help PLX
Old Feb 19, 2008 | 07:38 PM
joeatl's Avatar
Help PLX
http://www.holley.com/0-80508S.asp
that is the holley im thinking about getting. It has 2 fuel inlets though..... So do i run a second from the tank or what?
Old Feb 19, 2008 | 08:05 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Help PLX
No, you use something like this.
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: Help PLX
http://www.jegs.com/webapp/wcs/store...10301_-1_10267
Take you're pick from any of these. The ones for holleys that is. Are you running a mechanical pump or electric? If electric then you can always get a regulator with 2 outputs and just run lines diredctly off the regulator. Just put a guage after it somewhere(preferably on the primary line).
Old Feb 19, 2008 | 08:06 PM
Air_Adam's Avatar
Re: Help PLX
Haha! Beat you to it!
Old Feb 19, 2008 | 08:08 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Re: Help PLX
Yeah!! Had to stop typin to play chase with the dog!!
Old Feb 19, 2008 | 08:27 PM
joeatl's Avatar
Re: Help PLX
mechanical is alredy installed
Old Feb 20, 2008 | 09:23 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why?
ZZ3Astro
Sep 8, 2014 12:07 PM
TheExaminer
Aug 23, 2014 01:50 PM
jaweiss
Jul 23, 2011 09:58 PM
MuttlyTheWetDog
Jun 15, 2008 03:47 PM
neat
May 26, 2005 03:37 PM
