Carb Swap and new Intake
Old Mar 12, 2008 | 03:35 AM
pyrofire127's Avatar
I've got a 90' camaro RS with a 350 from an 88gm truck.
im sure this is already explained somewhere so could someone link me to a TBI to carb swap?
im new to carb so what would be a good performance carb i was told to aim around a holley 650?
and what Intake would work best with that? (none vortec)
Thanks guys
Old Mar 12, 2008 | 06:13 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: Carb Swap and new Intake
here you go----
https://www.thirdgen.org/carbswap
Old Mar 12, 2008 | 10:35 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A 650 would be a reasonable choice. So would a non-computer q-jet. Do you have any upgrade plans for the 350?
Like the linked tech article says, Performer or Performer RPM. If you keep the truck heads and don't have big performance plans, a Performer in the '87-up configuration would bolt right on and work well. The Performer RPM isn't available in '87-up config, and probably wouldn't do you any good as long as you have the truck heads on, anyway.
Weiand & Holley make equivalent intakes to the Performer. You might be able to find a ZZ4 take-off manifold on eBay, craigslist, racingjunk, etc, for less than a new intake. But, it wouldn't have the '87-up bolt pattern. Not a biggie, just elongate the center two mount bolts on each side so the bolts will line up with the bolt holes in the heads. But, getting an '87-up manifold would be a lot easier.
Old Mar 12, 2008 | 04:37 PM
If you keep the truck heads and don't have big performance plans...
I plan on slowly building this car up to high performance. soon ill have a dayly driver and will be able to get to things like the heads, cam, ect.. for now though i think im just going to switch to carb, and new intake. the higher the performance the better.. it will just take a good amount of time for me to finish it haha
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
