I am getting 113 vette heads for a 350 build-up. Which Edelbrock manifold works with these heads? Are the middle intake bolts at the GEN I angle of the TPI angle? Edelbrock makes a 2101 for Gen I and a 2104 for Gen II.
Can someone who has used these heads on a carb motor provide guidance?
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,454 Times in 1,874 Posts
Early style, all intake bolts at the same angle...
Also, those heads don't support EGR, so there's no need in buying that version, unless you just need the valve to be mounted and hooked up for the visual.
Thanks!
That's what I was hoping. Save me some money!
robertfrank
close
- Join DateApr 2004
- LocationSalt Lake City, Utah
- iTrader Feedback Score(27)
- Car1988 camaro "SS"/ 1991 305/T5
- Engine383 LT1 in progress/LT1TBI 355 soon
- TransmissionProbuilt 700R4 3600 stall/ T5
- Axle/GearsMoser axles, 3.42 Eaton Posi
- Liked:62 Times in 44 Posts
This is actually a good question for me as well. I have a set of ZZ4 heads that I want to use and I'm not looking forward to having to elongate the two middle holes. What would be a good intake for these heads? Sorry I didn't mean to hijack.
Quote:
Carb of EFI?Originally Posted by robertfrank
This is actually a good question for me as well. I have a set of ZZ4 heads that I want to use and I'm not looking forward to having to elongate the two middle holes. What would be a good intake for these heads? Sorry I didn't mean to hijack. Stock hood or cowl induction hood?
robertfrank
close
- Join DateApr 2004
TBI. will have a cowl hood.
five7kid
close
Let's clear something up here:
Gen I was 1955 to 1995. Bolt angles changed in 1987. So, there are 1955-1986 Gen I heads, all of which had the bolts at 90 degrees, and 1987-1995 Gen I heads, which had the center two bolt holes on each side at 72 degrees.
Of course, the factory couldn't keep it simple, so Vettes kept all the intake mount bolts at 90 degree through 1991 - they didn't change in '87 like all the rest. Of course, in 1986-1/2, Vettes started using aluminum heads, too. The bolt angles stayed at 90 degrees with aluminum heads. The ZZ3 & 4 crate engines (not completely sure about ZZ1 & ZZ2) used the Vette aluminum heads.
Which means, 113's are all 90 degrees, therefore Gen I '86-earlier.
Gen II started in 1992 with the LT1 in Vettes.
