efe
Old Apr 6, 2008 | 07:01 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
efe
Hi,
Can anyone tell me wherethe thin plastic pipe, that I identified as having to do with something called EFE, connects? To the carb, manifold or what? I have an lg4.
Old Apr 7, 2008 | 11:33 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Re: efe
Eh...might be EGR, connects to the passengerside manifold.
Old Apr 7, 2008 | 01:59 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: efe
You good? Or still got a question? If you're still in 'I don't know land' you may have to post a photo. Thin plastic vacuum line is used at the EGR valve and the Vac sensor. EFE uses normal vacuum line to a thin metal vacuum line to the valve.
Old Apr 8, 2008 | 07:44 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Re: efe
Identified itm as EFE valve, positioned where manifold and exhaust connect. BVut where should the hose from it connect? Carb, intake?
Old Apr 8, 2008 | 08:39 AM
naf's Avatar
naf
Re: efe
Hose should connect to the thermal vacuum switch (tvs) on the intake water neck then to a vacuum port on the carb base. It may be connected to the carb base through a tee to the smog pump vacuum line.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Linson
Nov 12, 2015 08:09 PM
xxblade31
Sep 21, 2015 01:36 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Big Z
Carburetors
21
Jul 14, 2003 12:47 PM
