carb + HEI
Old Apr 6, 2008 | 10:38 PM
blue_iroc_z28's Avatar
Car: 1987 pontiac trans am gta
Transmission: 5 speed
Axle/Gears: 3.43 posi
carb + HEI
my car was converted to carb from tpi before i got it and it looks like a hack job, my distributor does not have the vacuum advance hooked up which port on the carb should i use? ( q-jet) and another question my car still has the hei distributor but i heard if its still hooked up to the computer that it is in ''limp home'' mode, what can i do about it? sorry if its obvious but im a noob .
thank you,
Old Apr 7, 2008 | 10:19 AM
Re: carb + HEI
Old Apr 7, 2008 | 10:36 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: carb + HEI
if it has vacuum advance then there is no computer hookup for the distributor. Is it a computer controlled Q-jet or a non-cc one?
Old Apr 7, 2008 | 02:31 PM
Re: carb + HEI
non cc
Old Apr 7, 2008 | 03:04 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: carb + HEI
That is going to depend on the idle vacuum, camshaft, cannister type and
your intention for the timing curve.
Generally, on a stock engine, you can use the manifold port for the distributor
advance.
You must check your base timing, and full advance when doing this. Adjust
as needed.
Base timing w/ vacuum should be around 6-10 degrees
Base timing w/o vacuum might be about 15-25 degrees
Part throttle advance will sit around 45-55 degrees, and should roll off
as the throttle blades open. If you have an adjustable vacuum cannister, you can dial this in nicely.
Full advance for a stock motor will be best in the 36 degree range (+/- 2, usually 38 degrees)
The full advance is most important to check.
Old Apr 7, 2008 | 10:48 PM
Re: carb + HEI
advance.
well i found what he used the manafold port for so i took it off and put it on the distributor, it made a lot of difference it smoothed out the idle and it feels like it has more power. i have not checked the timing yet (need to get a timing light). thanks for the help.
2012sergen11
Oct 13, 2015 07:38 PM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
lanceflame44
Sep 25, 2015 12:28 PM
