mechanical fuel pump problem...
Old Apr 16, 2008 | 02:10 AM
stelios_z28's Avatar
Car: 1982 FIREBIRD-1983 CAMARO
Engine: 305 LG4
Transmission: TH350-TH200
can a mechanical fuel pump break down via high temprature?last night my trans am died on the highway...after 10 minutes start again...after 1 mile the car stopped again...and wont start....i try to start up after 10 minutes and the car start normaly..but after 1 mile again the car stopped!can this caused by the fuel pump?my car is equiped with a mechanical fuel pump and a 4bbl holley carb.
Old Apr 16, 2008 | 05:20 AM
battyice's Avatar
Car: 1985 Z28
Engine: 355 topped with Dart heads
Axle/Gears: Stock axle with 3.73's
Re: mechanical fuel pump problem...
Mechanical fuel pumps can fail, but they are usually a pretty robust unit. It is easy to see if the carb is getting fuel, take the air cleaner off and open the throttle. Watch to see if fuel comes out of the accelerator pump nozzles. If you determine that the carb has fuel, start looking at the ignition. A failed HEI module can behave like you've described.
Old Apr 16, 2008 | 05:30 AM
Engine: 305 LG4
the last time that the module was failing the car was backfiring.although the distributor is brand new...hei distirbutor with brand new module and brand new cables and sparkplugs!
Old Apr 16, 2008 | 11:41 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Next it dies on the highway see if it's from fuel or spark then. Check to see if you have fuel coming out of the shooters. If not, replace the pump and go from there.
They are cheap over here, I imagine it'd cost you an arm and a leg, maybe even a kidney?
Old Apr 16, 2008 | 02:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The pump doesn't fail with temperature, but you can have vapour lock.
Old Apr 16, 2008 | 03:12 PM
Engine: 305 LG4
ok guys!i just replace the fuel pump and everything seems to work properly!i just come back from a big ride!as for the price of the fuel pump..as i check usa prices are between 26 to 35 dollars...i pay for it 85euros!thats about 120 dollars!!an arm and a leg indeed!!!thanks for your heps guys!have a nice day!
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
