spark knocking
Old Apr 18, 2008 | 02:20 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
spark knocking
whats up guys,
my engine is spark knocking every time the trans goes into second gear.
it also happens when i accelerate hard. the timing is dead on.
i have a small holley carb with vacum secondary, i also have the biggest cam possible,without having to have a stall converter.
could the vacum be too low coming from my carb going to the distributor and the power brakes?
if so what can i do to correct the problem?
its killing my horse power!
Old Apr 18, 2008 | 06:03 PM
battyice's Avatar
Car: 1985 Z28
Engine: 355 topped with Dart heads
Axle/Gears: Stock axle with 3.73's
Re: spark knocking
Can you post some more information about your engine and cam? Also, what is your base timing set at? How much total advance are you running?
Usually pinging is caused by excessive ignition advance, too hot of a spark plug heat range, carbon deposits, or a lean condition.
If you have a large cam with a street-oriented carb, it could be running lean. How do the plugs look? What color are they?
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
