Vacuum level?
Old Jun 3, 2008 | 07:03 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Vacuum level?
What is considered a good vacuum level at idle.I have a cc qjet on a 305 lg4,
and warmed up,with a idle of 900,i'm getting 21" of vacuum,and idle of 600 in drive gives me 17 to 18".The gauge is hooked up to the bottom rear port on the carb,which is manifold vacuum I presume.Are these good levels?.
Thanks,
Alicat.
Old Jun 3, 2008 | 07:41 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: Vacuum level?
Vacuum levels are determined by several aspects of the engine combo.
Depending on the valve timing, runner volumes, exhaust flow and many
other things, you can determine whether the vacuum reading is sufficient.
If you are reading 16-18 in./hg. of vacuum, on a 305, I would guess it's
fairly stock and the level indicates a fairly sound motor. Looks good!
Old Jun 4, 2008 | 04:16 AM
alicat's Avatar
Axle/Gears: Stock.
Re: Vacuum level?
Yes it's stock as far as I know,and seems in good condition,although my oil pressure at idle is only 25 psi,but it runs strong,and does'nt leak or lose any oil.
Old Jun 4, 2008 | 06:47 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
Re: Vacuum level?
25 PSI is more than enough at idle. With the proper bearing clearances
and volume, even 10 PSI is enough pressure.
Everything is fine, don't worry. Your engine is healthy according to those
values.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
