Choke light!
Car: 1984 Camaro Sport, 1985 camaro
Engine: 305 v8, v6
Choke light!
Hi all,
Im new to the thirdgen scene and ive searched through the boards and found some help but not an exact answer to my situation. I have an 84 Camaro Sport. Today when i stopped at a light my lights started to dim my battery gauge started going down and my choke light came on. As i drove the lights and the gauge kept on going up and down. So i was wondering if anybody can explain to me whats going on
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Your alternator is not charging properly. The choke heater relay is tied to alternator output, meaning it doesn't close until the alternator is charging. When the choke heater relay is open and the ignition is on, the choke light will come on.
Fix your alternator and the problems should go away.
Engine: 305 v8, v6
Re: Choke light!
ahh ok im gonna try to get a new one in there tomorrow, Also i was wondering what carburetor one would recommend thats decent
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Choke light!
The factory carb's more than adequate. It's computer controlled and removing it requires replacing the dist and lock up control for converter. If it's running poorly it may need some attention or a rebuild.
Engine: 305 v8, v6
Re: Choke light!
Ok I see, Thats what alot of people have been telling me to stick with the stock carb. Now back on the alternator problem, Yesterday as i was driving and gave the car gas the belt would squeal. Could it be possible i just need a new belt?
Engine: 305 v8, v6
Re: Choke light!
Ok so i tightened the belt and the squealing stopped but im still have ing the dimming lights, gauges dropping and rising, choke light steady when braking flashing when driving. So im going to bring it to an advance to test my alternator but my father said he doesnt think thats it because theres a clicking sound coming from that area so he thinks it something else. any other ideas?
Car: 84 Firebird
Transmission: turbo 350
Re: Choke light!
Look under you hood on the pass. side and see if the choke wire is touching metal or something . Mine did that and the insulation on the wire was cracked and it was touching metal and was doing the same thing your talking about ..
Engine: 305 v8, v6
Re: Choke light!
Hmm i checked the wire and it didnt seem to be touching anything. I feel like such a noob but which one is the choke heater fuse?
Engine: 305 v8, v6
Re: Choke light!
Ok well yesterday i had to bring it in for a inspection and i asked them to test the alternator and it was 14.5 off and 18 on. so im guessing there is a short somewhere
