another qjet question question
Old Jun 3, 2008 | 09:29 PM
jordo2114's Avatar
well i finally got my ccqjet in better shape than before now it gets perty good mileage now i wanna fine tune i need to know what rods and hanger to use it has the stock ones now i dont know what they are ill check tomorrow but the motor is a 350 with very small cam almost stock and i plan on putting an wieand dual plane intake with egr valve ( gas mileage) on the top what would be best hangers and rods for or how do i go about determining this info
Old Jun 6, 2008 | 10:51 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: another qjet question question
If it doesn't bog or stumble at the top end, then you probably have the right rods/hanger already.
Otherwise it's a guess and check thing. Or use a wideband to determine if you're too rich/lean when in the secondaries. Not mathematical formula that you can use
MustangBeater20
Oct 29, 2022 09:20 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
