edelbrock thunder series vacuum help
Old Jun 16, 2008 | 08:55 PM
91 camaro 383's Avatar
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
ive got my car running but there was a whistling noise and i forgot about the vacuum port on te back of the carb so i plugged it with my finger to make sure that was it and it was. when i plugged it it killed the motor. what is that vacuum port for and where is it supposed to be hooked to?
Old Jun 16, 2008 | 10:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is your brake power booster hooked up?
Old Jun 17, 2008 | 06:11 AM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: edelbrock thunder series vacuum help
ya i ewnt off the intake manifold to a vac reserve canister to the booster.
Old Jun 17, 2008 | 12:47 PM
five7kid's Avatar
Factory carb set-ups had the brake booster vacuum going to the carb base.
If you've got all of your vacuum needs covered (PCV?), then plug it. If it ran with it open and died with it blocked, then you've got some tuning to do.
Old Jun 17, 2008 | 01:39 PM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
ya i probably just need to tune it when its plugged lol duh. cause we had it idling with no chooke or nething then i was just overlooking making sure everything was good and i noticed that and plugged it and then it died.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
sreZ28
Oct 22, 2015 08:21 AM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
