MAP vacuum source
Old Jun 27, 2008 | 02:24 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
MAP vacuum source
Hi,
Trying to get all the vacuum lines right...
Nothing connected to the MAP, a bit worrying I guess. Where should I connect it? Can I put a T where the HVAC and cruise control gets its vacuum, manifold behind carb?
Oh..forgot, I have a TA 85 lg4
regards
Hasse
Old Jun 27, 2008 | 09:35 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: MAP vacuum source
if you are referring to the sensor that is hanging in the back near the ac equipment, that is the BARO sensor. It is open to the atmosphere. The MAP sensor is on the drivers side firewall, to the outside of the brake master cyl and I think it's line attaches to a manifold vacuum port at the rear of the carb base plate
db057
Jan 10, 2020 08:55 PM
bbsr72
Apr 2, 2016 09:12 AM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:50 PM
