Mech Secondaries not opening
Old Jun 28, 2008 | 09:50 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
So I finally decided to check if my secondaries were opening all the way and they're no where near what they should be. If I hold it to the floor they maybe open 15 degrees. I have a BTO TV cable and throttle cable bracket. I had to modify it originally by adding a piece of steel to extend cable out so it wouldn't bind. I'm using the stock 91 TBI cable that I had on my car. The carburetor is a 700DP. I can open the secondaries by manually opening the throttle but it takes A LOT of travel. The carb is second hand so I have no idea what the guy before me did to it. Anyone out there run across this problem or something similar.
Old Jun 28, 2008 | 12:14 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Mech Secondaries not opening
are you running the bolt through the proper hole in the carb arm to get full travel?
Old Jun 28, 2008 | 05:17 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
I'm pretty sure but which hole is it so that I make sure?
Old Jun 28, 2008 | 08:32 PM
xpndbl3's Avatar
Car: 1984 Z28
look at your arm and see if there is a lower hole, that would probably be it if your stock cable doesn't work.
Pac J
May 17, 2020 10:44 AM
racereese
Oct 10, 2015 09:39 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
RedLeader289
Sep 23, 2015 06:50 AM
gta892000
Sep 16, 2015 12:37 AM
