Setting up a Holley
Old Jul 11, 2008 | 06:39 PM
davep_96's Avatar
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
Setting up a Holley
Hey guys I just got my engine running in my car and I was wondering if anyone could provide me with info as to how to tune/set up a Holley 600cfm carb(vac. secondaries). The car runs, we got the timing set, but I have no clue how to set up or tune a Holley. I basically only know how to adjust idle by using the idle screw. I see that there is a Holley tuning sticky but I need to do basic tuning first. Any info would be greatly appreciated.
Also, we took the car for a test drive and we found out that the gas pedal has a very limited distance it can travel before it hits the floor. How would you go about adjusting this? I have both of the kickdown brackets installed that Holley says to use with a 700r4.
Edit: Actually, the pedal doesnt make it to the floor. It only moves about an inch and a half, and doesnt even hit the floor at all.
Old Jul 12, 2008 | 12:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Set up: The adjustments you make prior to installing the carb on the engine.
Tuning: The adjustments/changes you make after the engine is running based on how it runs.
The sticky covers them both.
Frozer!!!
Jan 19, 2024 04:55 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
355tpipickup
Aug 19, 2015 10:02 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
