Q-jet new choke thermostat and no choke in morning
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
I couldn't get the choke to work right so i slapped a new thermostat on it. Before the choke wouldn't fully open or close. Now it will only stay fully open. There is 14+ volts to the therm when the car is running. What did I do wrong. Ambient temp is cold enough where choke should close at least some of the way.
1987 camaro w/ 350 and rochester carb
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Q-jet new choke thermostat and no choke in morning
How did you adjust the tension of the choke coil?
Car: 1987 camaro
how am I supposed to set it? I didn't know that it had to be set. I'm sure that that's the problem.
Engine: 383 Carb
Transmission: 4L60
With the engine cold, turn the choke thermostat housing until the choke is just closed. From there you can turn it either way to shorten or lengthen the time the choke stays cold after starting.
Car: 1987 camaro
Thanks man. Do I have to drill out my rivets again to do this? My thermostat will be rotated so that the wire attachment is toward the from of the car. Seems a bit extreme to me. I'll give it a shot though.
Engine: 383 Carb
Transmission: 4L60
Did you rivet the new one in? Normally when you replace the choke, you drill the rivets out and tap the holes for screws.
Car: 1987 camaro
Yep, riveted it in. What size tap and screws would you suggest? 1/8?
Car: 1987 camaro
ok, that wasn't too helpful. Thanks for the rest of the advice though.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Just use self-tapping screws for the choke therm housing. Thats usually whats supplied with most kits, and it works just fine. Too much unnecessary hassle to tap it for a machine thread.
But yes, turn it back untill the choke blade is just barely closed with the engine not running and cold. As soon as it fires up, the airflow should suck the plate open to a gap about 1/8" or so, roughly. It will progressively open from then on as the engine warms up.
You'll also want to set the fast idle as well if its off... I usually set it to somewhere between 1300-1600 rpm cold, which usually goes up to about 2000-ish once the choke is open. Set it fast enough that it runs reasonably well as soon as its started, and is not running rough or acting like to wants to stall (it will do this if its set too low). Every engine is different, but something around 1500 rpm cold is usually a pretty good place to start.
Car: 1987 camaro
I think that the fast idle will be right when I get the choke working. It was fine on the LG4. Any idea what size of self tapping screw you used? My thermostat kit came with rivets. Tapping the holes would be no problem for me provided I have a suitable tap. I've tapped a few holes in my day.
Car: 1987 camaro
yeah I found a 10-24 in the toolbox. Now i just need to get my drill back from my mom's husband.
Transmission: 4L80E/4L80E
I'm thinking that you didn't get the choke mechanism tang engaged with the choke thermostat.
Many of these thermostats will only mount in one position (have a slot & tab to keep them in the "proper" position). An emissions pre-adjustment thing, you know. That's why the rivets were there.
Car: 1987 camaro
I got the tang engaged. Like I said though, to make the choke close when cold I would have to move the electrical plug from the 6:00 position to the 3:00 position. The tang was at the 3:00 position when the choke was open. Is there any other way to adjust this? Did I break something? What's the deal?
Engine: 383 Carb
Transmission: 4L60
The position of the plug doesn't matter too much, as long as you can get proper tension in the coil to close the choke.
HoosierinWA
Oct 7, 2015 10:15 AM
1988, 305, carb, choke, jet, qjet, replace, rivited, screws, tapping, therm, thermastat, thermostat, thermostats, work
