Load Knocking at idle and acceleration
Old Jul 17, 2008 | 05:06 PM
justingc43's Avatar
I recently purchased a 86 z28 camaro. the kid before me installed a rebuilt 350. runs starts and everything but there seems to be a knocking sound at idle and during acceleration. He said if i get it tuned and timed right it should go away. i was wondering if hes right or pulling my leg and have a bigger problem. It is not a stock motor, has comp cam, 305 heads, edelbrock carb headers. msd ignition. it used to be a 305 tpi. any help would be apprecciated.
Justin
Old Jul 17, 2008 | 08:26 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: Load Knocking at idle and acceleration
You can use a tube to listen to the engine; be careful & rest it on the engine to hear/help locate source of the knock. water pump? belt on way too tight around water pump or other accessory? something else?
Old Jul 17, 2008 | 09:09 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Can you take a video and post it for us? What is the oil pressure at idle? The noise is actually there at idle? Does it increase with rpms and pick up speed? Describe it in as much detail as possible.. Also am I correct in assuming that it's carbed with a vaccum advance dist?
Old Jul 17, 2008 | 09:16 PM
justingc43's Avatar
il get a vid on it as soon as possible. it is a carb with a vac. the oil pressure seems to be perfect at idle. its barely there at idle as u accelerlate it gets loader, i can still feel the car pull just i know it has wayyyyy more. I just did an oil change, i am not positive but i think it got worse when i did it
Old Jul 21, 2008 | 08:38 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
A typical problem would be trash in a hydrulic lifter, you would be able to isolate the knocking to the specific lifter easily with a peice of tubing or long screwdriver up to your ear.
Old Jul 23, 2008 | 11:35 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
try to retard the timing a hair at a time to see if the sound goes away. I had the same problem today.
Old Jul 24, 2008 | 05:08 PM
scooter500's Avatar
Car: 87 Camaro Z-28
are you sure the belts aren't set too tight by the previous owner? it can cause the exact same symptoms
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
