swapping HSR for carb
Old Jul 28, 2008 | 05:15 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
I got a 355 w/ vortec heads and LT4 hot cam on it, and its got the HSR fuel injection. It just isn't making enough power, I read an article where they had the same motor but with a rpm dual plane intake and a 750 carb it made 420hp, and I can get the carb and intake off of a friend and sell the HSR. Just wondering what I will need for the swap?? Heres what I know so far:
1)New distributor, what kind??? vacuum advance?? or can i lock out my old distributor??
2)Fuel pressure regulator- return style
3)Intake gaskets
4)Rig up overdrive and fans to switches
anything else?? I'm going with a holley 750 and rpm street intake
Old Jul 28, 2008 | 05:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: swapping HSR for carb
i dont think its the HSR thats limiting the motor but if you go carb you will need bracket for TV cable to keep the tranny shifting and lockup the converter by switch if you like
Old Aug 1, 2008 | 01:49 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I agree. The HSR has decent potential. But if you went for it, you would need a vacuum advance distributor and the return style FPR you can get from mallory. Don't know the part number off hand though but summit sells it.
Old Aug 1, 2008 | 02:31 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
You could use these parts:
afpr Mallory:http://store.summitracing.com/partde...5&autoview=sku
Summit distributor: http://store.summitracing.com/partde...5&autoview=sku
Although, I would suggest a upgraded unit with better coil, module, cap and rotor.
Like this:http://store.summitracing.com/partde...5&autoview=sku
I think these are the vortec intake gaskets:http://store.summitracing.com/partde...t=NAL-89017465
Throttle cable bracket:http://store.summitracing.com/partde...5&autoview=sku
Dropbase air cleaners "depending on your hood clearance":http://store.summitracing.com/partde...5&autoview=sku
I think the fuel pump and fan will still work with the ECU still intacked.
Not sure on the converter lockup.
Hope this gets you in a ballpark. You should be able to pickup most of these parts used.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
