superam to carb/distributor
Subscribe
Jul 29, 2008 | 05:24 PM
I just bought a performer intake, a 750 mighty demon, mechanical secondaries, a vortech carb enlclosure and a 4309 mallory pressure regulator with boost reference. I put in a vac advance HEI distributor, but need help on the wiring..does anybody have a wire diagram or can they explain what distributor wires go where and since all of my tpi wires are lying around, where do they go? do i splice into them?... on the new dsitributor, I guess one is tach, batt, ground and there are a couple of other wires. also, eventually i need to switch to a smaller distributor without vac advance and with msd-BTM, so the vortech carb enclosure fits right, and i will be plumbing my existing supercharger into it, but that is another story. Aside from the distributor, i have the throttle bracket, the fuel lines all hooked up, what else really has to get hooked up to start it? what do i do with all of the loose vacuum lines, just cap them? the pcv valve goes to the back of the carb and the bracke booster goes to the intake i guess. also the vacuum canister vacuum lines go to where? will it still work. what else do i need to consider? thanks -j
Reply 0
Subscribe
