tach wire
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
tach wire
I am converting TPI to carb, with a hei vac advance distributor. which tpi wire is tach? i have to hook up power and tach, what does the tpi tach wire look like, what color? pics? thanks
Transmission: 4L80E/4L80E
It's one of the wires going to the coil. White with a stripe, if I remember correctly what I've heard ('86 is the latest I've dealt with personally).
If you got a small cap, separate coil vacuum/mechanical advance distributor, you could re-use your stock coil.
Car: 1987 GTA
Re: tach wire
actually it's a '87, i will look for that color wire, can anyone confirm? I have a large cap version...
I know. That's the year they went to the small cap distributor with separate coil. I haven't personally worked on '87-up 3rd gens. Therefore, I can't go out to the car and look at the wire for you.
I know this has been discussed on the Board before. Otherwise, I couldn't even offer what I have to this point.
Have you tried searching for "tach wire"?
Car: 1984 z-28
Engine: 305H.O. L69
Axle/Gears: 3.73 G80 GT4
Re: tach wire
alldata wont give me an exact location of where it plugs in at but the electrical diagram is stating its an all white wire specifically it states .35 WHT one one side of the wire and 121 on the other side of the wire shows it plugs into the 32 pin c-d connector at d4 (staring at clip not ecm with the lock clip on left side it would be 4th down on the right side) on the ecm also states pure white wire
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
Re: tach wire
large cap HEI distributors should have a white and red wire connected into the cap, the white wire is your tach lead, red is power. the other 5 wires that come from the base of the dizzy are for your timing advance and ICM, which is not needed for carb.
eightsixseven
Dec 16, 2024 01:50 PM
