new electric choke hint?
Old Aug 4, 2008 | 05:49 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
I put a new one in & soldered on a new choke wire connector (both factory style). But when starting the engine cold, the bottom plate of primaries stay closed until the choke cams are lightly touched. Didn't do this with old choke. Adjusted per previously posted Thirdgen advice. Have had the top off recently to adjust rich stop but thought all was together right & didn't touch choke cam parts. Any ideas?
Old Aug 6, 2008 | 08:43 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: new electric choke hint?
any thoughts on this? I did not touch linkage. linkage is clean. just replaced electric choke....
Old Aug 6, 2008 | 09:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You mean the choke doesn't close and the fast idle isn't set unless you press on the gas?
Old Aug 7, 2008 | 08:37 PM
scooter500's Avatar
Car: 87 Camaro Z-28
the choke valve and fast idle appear set up correctly when pressing the gas but the base plate throttle plates are shut closed, so no air gets through and car can't start until pressing choke linkage.
Old Aug 8, 2008 | 12:24 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Adjust the fast idle. Under the choke.
Old Aug 8, 2008 | 08:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If they're closed, then the fast idle isn't set correctly.
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
lanceflame44
Sep 25, 2015 12:28 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
