going to carb-is this a good intake/carb??
Old Jul 29, 2008 | 09:33 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Im probably going to be going to carb pretty soon and im getting a 750 holley DP, and a eldebrock performer dual plane intake. My engine combo is a 355 with vortec heads and lt4 HOT cam.
Also i was wondering about distributors, should I just keep my electronic one and just lock it out or get a vacuum advance one??
Old Jul 29, 2008 | 09:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: going to carb-is this a good intake/carb??
You might be happier with a 650 DP instead of a 750. Get a vacuum advance distributor.
Old Jul 29, 2008 | 09:45 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
http://www.chevyhiperformance.com/te...ild/index.html
got same combo^^
i'd probably go with a 650 but im getting the carb from a friend for 75 bucks and he doesn't have a 650 just the 750. Still would work good?? tell me more about the distributor
Old Jul 29, 2008 | 10:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What do you want to know about the distributor? Using the one you've got isn't an option.
Old Jul 29, 2008 | 10:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What are you going to do with the car?
Old Jul 30, 2008 | 10:23 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
talked to some pros at the drag strip today he recommended an air gap and a 750 and a vacuum distributor. I was wondering if i could just lock out my distributor or if i had to get a vacuum distributor. I plan on doing some strip and its my daily driver for the summer, but I only drive like 250 miles max a month.
Old Jul 30, 2008 | 10:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If it's going to be street driven, you need a vacuum advance distributor. You could lock the advance out if you had a big cam and high stall, but the weenie little LT4 doesn't come close to that. Even then, you'd want vacuum advance for part-throttle operation.
I'd still go with the smaller DP for something that's going to have any daily-driver use. It'll be easier on the gas bill.
Old Jul 30, 2008 | 10:31 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
If I could find a 700 or 650 I would for the gas or even a VS carb, but for 75 bucks for a carb I guess I can't be too picky versus 450 bucks for a new carb, jeez they used to be like 40 bucks
Old Jul 31, 2008 | 03:43 AM
EvilCartman's Avatar
Car: '82 Z28
I'd go with the performer RPM instead of the regular performer, gives room to grow and it's a better manifold.
Old Jul 31, 2008 | 12:29 PM
five7kid's Avatar
How do you plan on using the car?
Old Jul 31, 2008 | 01:01 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
I dont know what you mean how i plan to use it, its a summer street car that sees some strip. I don't know if its the performer or rpm but im getting it for 40 bucks and the carb for 75.
Old Jul 31, 2008 | 10:21 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
it turns out its the regular performer guess ill have to shell out 200 bucks for an rpm. I don't really care about gas mileage i'd be happy if i got 12mpg as long as im making more power. How about the summit HEI distributor?? its only 89 bucks seems like a good deal are they any good or junk?
Old Jul 31, 2008 | 11:52 PM
five7kid's Avatar
Originally Posted by Rayzor32
I dont know what you mean how i plan to use it...
Are you going to drive it on the street regularly? Street/strip? Drive it only to the strip? Trailer it to the strip?
You should only consider locked-out advance for the last two.
The Summit HEI is okay. The $89 one, if memory serves, has aluminum cap and rotor terminals - not ideal. To get brass, you need to get their more expensive on, or buy a cap/rotor with brass terminals and install them on it.
Old Aug 5, 2008 | 07:43 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
I went and ordered the performer rpm, proform hei vac adv dizzy, and throttle brackets and its coming today and when it does im bolting it all up. Getting the regulator and carb off my buddy. If the 750 doesn't work hes got a 650 but it might need to be rebuilt or i could get an edelbrock 650 off another buddy for 40 bucks
Old Aug 5, 2008 | 08:25 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Let us know how things work out. Maybe you can get to the track soon.
Old Aug 5, 2008 | 08:43 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
yeah hopefully if i get it done today I can go to the track tommorow! ha not likely though theres gonna be a lot of stops at autozone and probably KnS looking for little stupid parts no one has!
Old Aug 5, 2008 | 08:54 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Oh yeah, The TPI throttle cable will be too long. I used a TBI throttle cable and it worked fine. I just had to trim the hard plastic that is between the cable bracket and the carb. It kept the carb from going WOT.
Old Aug 5, 2008 | 09:49 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
grrrr i just found out the distributor I ordered doesn't come with a coil!!! WTF!!!
Old Aug 5, 2008 | 09:51 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
might as well make sure its a upgraded coil.
Old Aug 5, 2008 | 10:13 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
http://www.jegs.com/i/Proform/778/66...002/-1/746781#
50,000 volt coil, 5k more than msd. But you have to click on "more details" and in fine print it says "without coil" wtf i had known that I would have just gone and ordered it. Called jegs they said they would send me the coil, we'll see if it comes if it does then 2 thumbs up for jegs. I'm sure summit would have said to go **** myself
Old Aug 5, 2008 | 02:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That'd be great if coil voltage was important.
Old Aug 5, 2008 | 09:21 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
yeah it will make the spark hotter. I got it up and running today with my old dizzy locked out till the new coil gets here, just got to get my throttle cable hooked up.
Old Aug 5, 2008 | 11:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
And a "hotter" spark means what?
Old Aug 8, 2008 | 08:55 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
okay jegs sent the coil, but i still need the friggen dust cover and wires. And the HSR throttle cable just has a "ball" end to it i need the end that goes on a carburetor. all the junkyards are gonna be super muddy today too
Old Aug 8, 2008 | 10:58 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
damn my oil is all milky WTFF!!! going to try changing intake gaskets and oil again, the kind I had on their were supposed to be reusable and I put rtv on them and changed the oil after. I also have to get some breathers as no ports to run a pvc valve. Only port is the rear port for the brake booster and I have to stack 3 gaskets to clear the carburetor. also doesn't look like i'll have room for an air cleaner. And I think the 750 is too bog i mean big
Old Aug 8, 2008 | 01:06 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
So your oil is milky from running the HSR? OR after the carb swap?
I use a dropbase air cleaner with a 2" filter under a stock 92 Z hood with blisters.
Old Aug 8, 2008 | 03:13 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if you're looking for a rmp manifold just buy a used one.. they are normally about $50 used on ebay or at a swapmeet.. i just sold one for $40.. also I'll take that crappy old stealthram.. pm me for address to ship it to. ps. I'm terribly jelious of your paint.. my car looks exactly like yours except faded to death..
Old Aug 8, 2008 | 05:23 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
my paint was shot it was faded too, you can see in the pic of the spoiler. I did a 3-stage buff job on it and it really brought it back to life.
The oily was milky AFTER the carb swap, I re-used the intake gaskets (dumbass!) and changed the oil. I had to RE DO it today, so far so good we will see if its milky tommorow. Cars running and driving right now just got to get my distributor wires and stuff and drop that in and then i can start carb tuning. Pulls pretty good with locked out timing at 6* and an out of tune carburetor.
I just need a thicker carb gasket to clear my rear vac port, ive got 2 stacked for now. We just test fitted my buddies holley drop base air cleaner and it fits so thats what i will go and buy.
Check engine light is on hahahaha gonna pull that bulb out, redo my gauge bulbs while im at it. The one fan runs all the time which i don't mind for now and the 2nd one i have rigged to a switch. My TCC still locks up, how bout that?? I also have that on a switch too. Had to do some throttle rigging but it works. Also got to delete my smog canister and buy another breather. And cut a bunch of wires off
I'll be putting the HSR up for sale pretty soon also
Old Aug 9, 2008 | 09:15 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Sounds like your getting close. You can play around with the timing and carb quite a bit.
Did you adjust your trans cable when you put on the new bracket? Check to make sure the throttle is opening all the way?
Old Aug 9, 2008 | 12:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I wouldn't recommend an Edelbrock intake with a dual-feed (two fuel inlet lines) Holley. I mean, they function just fine, but the problem is that Edelbrock puts the vacuum fitting for the brakes right directly under where the secondary accelerator pump is on the carb, so you have to either plug that fitting or use a carb spacer, and it becomes a big PITA if you plan to use PCV and power brakes.
What I suggest is a Weiand 8120 or 8150.
Old Aug 9, 2008 | 03:43 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
It clears fine with a 1/4" gasket. I also had to get a 14" drop base holley air cleaner. I think the 750 might be a little too big, its actually got a proform main body so that makes it a 780cfm and it doesn't have a choke which really sucks. And it won't stay idling in gear, oh well I don't mind playing around with it. I set the tv cable and the throttle opens all the way, I had to rig it up by crimping a terminal end on it loll but it works
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
