how to run E85
Old Aug 5, 2008 | 12:23 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
how to run E85
I was reading in a superchevy that you can buy a kit to convert a holley to be able to run E85 for like 200 bucks. does anybody think that is worth it? i know that E85 is about the same price as 89 octane. are there any pros or cons?
Old Aug 5, 2008 | 01:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
https://www.thirdgen.org/forums/carb...5-jetting.html
Be sure to read all 195 posts. . .
Old Aug 5, 2008 | 01:49 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
Re: how to run E85
i run e85 an i love it.
the quick fuel kit is for 4150 dp carbs.
it does not include new jets, new airbleads, and new boosters or squirters
i would suggets buying a whole new carb for e85. they are more but you get a high flow mainbody, billet baseplate and better bowls.
my e85 carb is tuned for a blowthrough turbo applicatoin. but i tried it on my s10 anyway.
drained all fuel out of system, added in new e85 bolted on carb. and ran.
within 3 passes i matched my et and mph on 114 race gas, on spray i was faster on a 175 shot than i had went before on 225. \
to buy 114 arround here now is anywhere from 8 -12: a gallon
and e85 has went down to 3.20 - 3.30
i have had no corison issues, and no problems with leaving it in between races. i love the stuff.
buy running it instead of 114 im saving about 60-80 a weekend on race gas
and the truck et dosent slow down due to temp outside. unless the track sucks. but the motor mph realy never slows
Old Aug 5, 2008 | 03:44 PM
five7kid's Avatar
Originally Posted by mattsv8_03
... on spray i was faster on a 175 shot than i had went before on 225.
What kit are you running? I've been trying to get fuel jetting info on nitrous kits with very little success. I need to pick up about half a second to qualify for PINKS All Out, figured a 100 shot would do the trick (and then some), but I'm assuming 147% flow area vs. gasoline, and don't have O2 capability.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
