warm up?
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
warm up?
Simple question, does it damage a carb'ed car to start it cold and immediately drive it, not letting it warm up?
Transmission: 4L80E/4L80E
You'll do more damage with a 20 minute warm-up than you will with a 20 second warm up, as long as you take it easy until the engine is fully warmed.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: warm up?
Yea, I try to give it 20-40 seconds or so. At least let it come off of full cold idle. Don't drive it when the starter is still pulling out for gods sake. Some girls I tell you.... ahem, but yea, no need to let it fully come up to temp, just don't give it more than 50% throttle until the thermostat is open (my easy way to figure out if the engine is warm yet).
tyeo098
Nov 30, 2015 06:27 PM
HoosierinWA
Oct 7, 2015 10:15 AM
