secondaries opening?
Old Sep 10, 2008 | 04:39 AM
84ak's Avatar
I have a holley 750, vacuum secondaries.........is there any way to tell if the secondaries are opening? Would it be really obvious if they weren't?
thanks
Old Sep 10, 2008 | 09:07 AM
Damon's Avatar
Re: secondaries opening?
Hard to tell if they are working properly. You shouldn't be able to feel them open. I usually wire them shut and make a run (and/or disconnect the arm from the vacuum chamber). If it noticably struggles in the upper RPMs it means they were opening before.
Old Sep 10, 2008 | 05:25 PM
danandamy's Avatar
Car: 86 Camaro
You can actually put a light paper clip on the rod from the secondary diaphram. If they open (rod pulls up) it will move the paper clip.
Pac J
May 17, 2020 10:44 AM
racereese
Oct 10, 2015 09:39 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
RedLeader289
Sep 23, 2015 06:50 AM
gta892000
Sep 16, 2015 12:37 AM
