TV cable corrector....
Old Sep 17, 2008 | 09:30 PM
Jammin'Trey's Avatar
So I am in the final stages of my motor swap, I need to figure out if my stock TBI throttle bracket that holds throttle cable and TV cable? I need to figure out out if this is all I need, Do I need a diffrent throttle/TV cable bracket too? I have a tourker II intake, so I have no idea. I am tryig to get this done this weekend its kind of time sensitive. I really appreciate all of you helping me get this swap done, I will post pics on sunday when it is finished.
Thanks in advance
This is the bracket i'm planning on using for my TV cable unless Im told otherwwise. http://www.jegs.com/i/B&M/130/64511/10002/-1
This is the carb Im ordering, http://www.jegs.com/i/Edelbrock/350/9907/10002/-1
Old Sep 17, 2008 | 09:45 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: TV cable corrector....
I've never figured out why that adapter thing is needed, I ran mine fine without it.
Old Sep 17, 2008 | 10:06 PM
From what I can tell, to not burn up trans by haveing to much or too little tranny fluid pressure. You have to have the correct geometry to have it work right, supposed to be like 1.125 in from center of throttle shaft or something to work correctly. I believe I will need this too http://www.jegs.com/i/Edelbrock/350/8036/10002/-1
Old Sep 18, 2008 | 12:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A TH400 doesn't need a corrector. TH700R-4 does.
I would highly recommend you reconsider your intake and carb choices. Both very poor, IMO.
Old Sep 18, 2008 | 08:24 PM
suggestions then...? What do you think for my TV corrector? All I need is the part that goes on the carb itself, my stock bracket will work on the torker II. My goals for the carb and intake is to be a good consistant daily driver and get Ok. gas mileage
Old Sep 20, 2008 | 03:46 PM
So is this corrector what I need? I have a edel. 600CFM performer carb for this motor. I need to figue out how to adapt my TBI throttle linkage to this edlelbrock carb too.
Also by any chance does anyone know what sockets I need to take out those weird studs holding in my serp., brackets?
Old Sep 20, 2008 | 04:07 PM
Ok so I have the TV button, and it measures the same dist. away from the center shaft as the stock TBI unit. 1.125".
I know I need the throttle cable adapter aswell now. I believe it would go in this hole (pic)......
Also is this the throttle stud you guys would reccomend I buy?
http://www.jegs.com/i/Edelbrock/350/8009/10002/-1
Old Sep 22, 2008 | 02:02 PM
five7kid's Avatar
If all you're looking for is a decent daily driver, the carb is okay, but not great. A simple q-jet would be better.
The Torker II is a very poor daily driver intake. It's single plane, which is its first disqualification. It doesn't do anything else well except lower the carb relative to the hood.
Old Sep 22, 2008 | 05:54 PM
actually, I am now running a Edelbrock 600 performer carb. I plan on getting a performer RPm intake, dual plane later.
Old Sep 23, 2008 | 06:01 PM
five7kid's Avatar
Right. A q-jet would be better.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
