need carb help!?!
Old Sep 23, 2008 | 10:23 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
need carb help!?!
well i just bought a 750 dp quickfuel ss from a member off the board...
after numerous moving of vaccum lines and helicoiling two studs in the intake mani i got it on and running, car ran real good, then the fuel line started leaking, tried fixing it today and things got bad.
yesterday the car started right up and ran real good, today it seem to run really rough, seemed like a miss, while driving i couldnt get the car over 3 grand and the whole time it sputtered and acted like it was trying to die jut around the block.
i dont hear it sucking air, and the idle doesnt hang so i dont thing its vaccum...
so my two thoughts are a fouled plug or the carb is loading up, niether of which i have dealt with so how can i spot them?
and if anybody has any other possibibilties let me know.
also i have a holley red electric pump and i had it pumping fuel for 10-15 seconds while i was checking for leaks, and i had started it after a hour or so sitting, it ran better but still real rough around 2500 rpms
thanks for any help in advance!
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
