Engine Surging
Old Sep 23, 2008 | 08:36 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Engine Surging
All of a sudden, unless I keep my foot on the pedal the idle rises and falls and eventually sputters out. It will only fire up if I pump the pedal a couple of times first. I also noticed a bit 'popping' from the muffler.
In case it matters, my base timing is only at about 8-10 degrees. Much more than that and I get alot of ping at WOT. The carb is a Holley 1850 VS.
Thanks,
Jon
JSD MOD 23/09/08
Old Sep 24, 2008 | 02:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Engine Surging
you've got a big vacuum leak.
Old Sep 24, 2008 | 09:40 PM
Car: '83 Berlinetta
Engine: 383 CI
Re: Engine Surging
Thanks Sonix. Yeah, that was my intial thought. This all started a day after one of the headers started leaking. I thought that I had dislodged a hose while changing the header gasket (which is still leaking)
The only Vac. hoses I have are for the brakes, PCV and one out the front of the carb (no 'timed' port). All seem fine. I changed the gasket between the carb and the intake to no avail. I did change the intake this past winter. If I had a leak there could I hear/feel it?
Thanks,
Jon
Old Sep 25, 2008 | 12:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You might have a clogged fuel passage inside the carb. Check your float levels as well.
Old Sep 25, 2008 | 06:12 PM
Jammin'Trey's Avatar
Re: Engine Surging
probably a vaccum leak...
Reddeath210
Oct 6, 2015 08:20 AM
jbd1969
Aug 17, 2015 07:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
