running rich
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
running rich
hey guys i have a 84 camaro 350 with an edlebrock carb, manual choke and performer intake. i noticed that my car is stinking like rich exhaust and dunno how to make it leaner. im new with carbs so go easy with me
. any help is appreciated
. any help is appreciated Supreme Member
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: running rich
two things i can think of..
1. is the manual choke open when you drive??
2. what is the fuel pressure??
oh and what size carb?? you sure the motor is a 350 and not a 305??
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: running rich
fuel pressure, float level, mixture screws, etc etc. Go on edelbrock's website and download their manual for whatever carb you have and set it up following the instructions.
Engine: 355
Re: running rich
i have the manual choke open all the time. dont have lever hooked up for it. my fuel pressure is bout 6 at idle and bout i think 10 driven. yes its a 350 i ran the codes before i dropped it in. my carb is a 600cfm
Car: 1984 Trans Am
Re: running rich
IIRC, the fuel pressure should never go above 6.5psi.. theres your problem.. what does your fuel system look like?? pump, regulator, lines??
and nearly everyone will tell you to get a pressure gauge after the regulator..
also, if you have the choke open at all times, see if you can take it off.. you dont want it accidentally closing on you..
Engine: 355
Re: running rich
Engine: 355
Re: running rich
my buddy said that when i romped on it, it smoked a tit bit and went away and he said th exhaust smelt strong. that a rich running condition?
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: running rich
dark black exhaust smoke is unburnt fuel....aka rich. check your plugs and compare them to this and tell us the results http://www.autolite.com/pdf/PlugTips.pdf
Engine: 355
Re: running rich
Engine: 355
Re: running rich
how would i lean my carb out? do i turn the screws in or out? im running 6 psi on fuel pressure any help is appreciated
Transmission: 4L80E/4L80E
The screws only affect the idle mixture. To change the cruise or power ratio, you need to change rods and/or jets.
Engine: 355
Re: running rich
it ran fine on my 305, we put it on my 350 and my buddy messed w the metering screws and it smells and it smokes on start up and a smitch black smoke on romping i
