mbolte
close
- Join DateNov 2006
- LocationTescott, Kansas 67484
- iTrader Positive Feedback100
- iTrader Feedback Score(3)
- Car1987 Camaro
- Engine350 dart ies comp cam intake carb
- Transmission700 r4, shift kit, 2400 stall
- Axle/Gears10 bolt stock
- Liked:0 Times in 0 Posts
i just got a quickfuel ss 750 and had it running real good at one time
then i got a fuel leak on the back pumper and while trying to fix that i had my holley electric pump pumping the whole time...now when i try starting it it coughs and sputters really bad...then i looked closer adn the front left fuel bowl is only a 1/4 the way full but the others are all completely full
could this be causing my problem...also would my holley red electric pump have messed it up when it was pumping fuel constantly while i was working on the fuel leak?
