hard cold start?
Old Sep 26, 2008 | 09:39 PM
yoshirocks702's Avatar
Car: 1984 Chevy Camaro Z28
Engine: L69 5.0L H.O.
Transmission: T-5 5 Speed
Axle/Gears: 3.73:1 Limited Slip Posi
hard cold start?
hey guys i just got a 1984 camaro z28 with the L69 305 and t5 trans and i im new to carbed cars and i was just wondering if this is normal when i start the car cold it takes quite a bit of cranking but when its hot it fires right up i have some videos if it helps in the dark one the car has been sitting for a week and the other its been sitting for a day i do give it two pumps before i start it...
Old Sep 26, 2008 | 09:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: hard cold start?
Check for leaking well plugs in the carb draining the bowls when it's parked for an extended period.
Old Sep 26, 2008 | 09:47 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
time to rebuild the carb, and epoxy the leaking plugs.
Old Sep 26, 2008 | 10:04 PM
thanks for the replies i have a 1985 firebird service manual that came with the car im wondering where or what im looking for in the diagrams or if in the service manual the well plugs have a technical name thanks
edit: using google i found what they look like i will try to have them fixed thanks for the help
Old Sep 27, 2008 | 10:27 PM
i tried starting the car again tonight i was playing with the throttle and choke on the carb to see how it works so i must have give it at least 20 pumps plus at least 10 foot pumps and it started pretty instantly but i will have that well plug checked also do you guys know how much amps the glass fuse is for the under hood light (whats left of the fues says 4 SFE)? thanks again for the help
edit: i figured out that what i wrote is the type of fuse i need
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
