Another carb engine question
Old Oct 15, 2008 | 11:07 PM
wht91z28's Avatar
Car: 1991 camaro z28
Engine: 305cu/tpi
Transmission: auto
I know I post a lot of stupid questions about stuff but it is cause I believe you have the most valuable information around. As you can tell I have a 91 z28 with a tpi 305. I was wondering what would I have to do make this engine work in my car. What wires do I keep? What gauges will work? Fuel lines and pump? http://www.yearone.com/serverfiles/f...ain2.asp?cat=G It is a crate engine from yearone. Any help would be grateful. If the link doesn't work it is on the yearone website part # CT350PC1
Old Oct 17, 2008 | 11:11 AM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
Re: Another carb engine question
Did you read the tpi-carb swap tech article? Also might want to check out the engine swap forum.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
