Non-Computer Carb Help...
Old Oct 20, 2008 | 08:07 AM
rtchaney's Avatar
Car: 89 RS
Transmission: Auto w/ evil shift kit; not my doin
Axle/Gears: It has a locker; not my doing
I've got a well built 305 with a remanufactured Quadrajet w/ an electric choke. When the car is warm it Idles perfectly at about 600 rpm. When it's cold out and I start it she belows black smoke and needs full throttle to stay running at around 750 rpm. When I adjusted the choke Idle screw, the car wouldn't start. So, help?
Old Oct 20, 2008 | 10:45 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Non-Computer Carb Help...
Do a search under my name for choke. I explained it a few times before, I wrote up a nice article with some pictures IIRC.
There's 3 settings you need to worry about, so make sure you set all three.
The "choke idle screw" is the "cold idle" screw.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
