new car know nothing about carbs
i just got a 91 305 rs with a carb that use to be throttle body now i have no fuel gauge speedometer and my tach is reading at 4000 and up ... HOW DO I FIX THISS !!!!!!
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: new car know nothing about carbs
Ah, you got a crappy conversion eh? buddy did it halfway, and backed out and left you with his shoddy work eh?
Fuel gauge - probably a loose connection behind the speedometer panel. Or just wiring at the tank. This has little to do with what's under the hood at all.
speedo - electric speedo in your year I believe. Again, probably a loose connection behind the cluster.
tach - probably same thing. Is the battery good? Does the car run?
yea basically its a cluster from a 90 and it has no wires except for 2 plugs in the back .. andddd i have NOOOOO interior dash lights!!! like URGHHHHHHHHHHHHHH
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
