stealthram to carb
Old Nov 1, 2008 | 08:22 PM
irocz436's Avatar
Car: 87 irocz
Engine: 436 chevy sbc
Transmission: th 400
Axle/Gears: 373
stealthram to carb
i got a question i have a 436 chevy in my 87 iroc engine made 595hp,645ftlbs tq. on engine dyno. when installed in car put stealthram intake on but the power is nowhere near that would switching back to carb make that much difference.any help would be appreciated.
Old Nov 2, 2008 | 02:10 AM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
Transmission: 700R4/ Edge 3400
Axle/Gears: 10 bolt/ Richmond 3.73
Re: stealthram to carb
A lil more info on the Stealthram combo would be nice. Was it a 58mm TB or stock. who tuned it? Im also assuming the engine was dynoed carbureted?
Old Nov 2, 2008 | 08:31 AM
irocz436's Avatar
Car: 87 irocz
Axle/Gears: 373
yes it has 58mm throttle body, intake was also ported , it was dynoed with team g intake and holley 750 hp carburetor. im running commander 950 ecu that i tuned with wideband oxygen sensor running 13.5 afr at idle to 12.2 at wot.cam is comp cams custom grind 242/245 duration .617int.621 ex. solid roller.was just wondering if it would beneficial to switch back to carb.thx.
Old Nov 2, 2008 | 03:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What exactly is the engine combo? Heads, cam, exhaust system, headers, ignition, etc..? Was it dyno'd with open headers? That will make a significant difference if its now got mufflers and full exhaust to the back on it, especially if its a small system, like a single 3" or something. That engine should have a 3" dual exhaust, or at least a 4" single at minimum.
Have you had it on a chassis dyno since the engine was installed? Has the EFI system been dyno tuned?
What transmission? Whats the converter stall speed?
From what I've been hearing, the HSR manifold is comparable, performance wise, to the LT1/LT4 manifolds, and there are LOTS of those guys making more power than you are with only very minor mods to the intake (like for the larger 58mm TB).
Old Nov 8, 2008 | 05:25 AM
irocz436's Avatar
Car: 87 irocz
Axle/Gears: 373
engine is 436 chevy 10.5 to 1 comp.rhs 200cc heads,comp cam solid roller,has 3 inch duals,hooker 1 3/4 longtubes,msd distributer cumputer controlled,400 th with 3600 stall converter.i havent had it on chassis dyno.just purchased wideband oxygen sensor to try and get it tuned a little better.just has hard time reving past 6000 rpm.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
