holley 4175
Car: 2004 GMC 2500HD
Engine: Duramax LLY
Transmission: Allison
holley 4175
Im just wondering if anyone is using a 4175 carb. The one I have is part # 0-80555C its a 650 Q-jet replacement. Im using vortec heads Comp 268 cam (.480 lift) Would it be a good perforamance carb for this?
Transmission: 4L80E/4L80E
It's a decent carb. The 4165 is a double pumper, I ran one of those for awhile summer '07, the car wasn't any quicker than with the stock CC q-jet (lots of data to prove that), and mileage was slightly worse. The 4175 has an electric choke, a definite advantage over the 4165.
I'd rather run a standard 4150 double pumper.
Engine: Duramax LLY
Re: holley 4175
Im also having trouble finding an intake to go with, I want a performer RPM because I feel the standard performer isnt enough but the RPM only comes in square bore so I would need an adapter plate but then I worry about hood clearance issues.
Engine: Duramax LLY
Re: holley 4175
After looking into this I want to use this carb as long as I can find an intake to go with it. I dont really want to use an adapter plate and I cant find the intake I need.
I need to find a SPREAD BORE VORTEC intake that is comparable to the performer RPM. My cam is comp cams 268XE which has .477/.480 lift. Any suggestions for intake.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: holley 4175
4175 has vacuum secondaries, the 4165 has mechanical secondaries.
Correct.
To the best of my knowledge, there is no Performer RPM Vortec spreadbore intake out there (and I've looked). The only choice is squarebore carb or squarebore to spreadbore adapter.
Engine: Duramax LLY
Re: holley 4175
Anyone think the RPM manifold and adapter plate w/carb will fit under the hood of an 85 T/A???
RaverRacerX
Mar 17, 2026 01:49 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
